Hi Deve, My speedometer cable just kinked up and I installed a new one and it did the same thing in half a block. I see there is a small spring at the connection on the transmission and it is tapered. Can't remember which way it should go in......any hints are appreciated! Terry
Speedometer cable destroyed
Never a spring on any Chevrolet speedo gear from the factory.
You will need to pull the speedo head out of the housing to access the plug.
The plug is half covered by the housing.
It requires a small sharp screw driver to dig into the side of the plug to pry it out.Last edited by Pre68Dave; 09-01-2017, 08:02 PM.
