Both systems use the Trans-Dapt 1028 Spin-On Filter Adapter. The Bypass models come with an orifice reducer which reduces the flow by adding a 1/16th inch (.0625) restriction exactly like the Stock system. This maintains the proper Oil Pressure. You can choose the kit that comes complete with stainless braided hoses, or just order the adapter mounting bracket. (or make it yourself) The mounting brackets come in three types. One uses the triangular motor mounting bosses that are found on a lot of engines after 1952. These are just aft of the generator or alternator and the perfect place to mount the adapter because it is low on the engine and puts less stress on the pumping system. Another type is mounted on the top frame rail exactly across from where those triangular mounting bosses would be if the engine were so equipped. The third mounts to the triangular mounting bosses but moves the adapter 6 inches forward to avoid the dual fenton exhaust manifolds. The idea is to have something for everyone. You can even use your original hoses if choose!
It's all here: http://devestechnet.com/Home/FullFlowOil
