Deve,
Had the 235 out of my 58 Apache (T/F trespasser) O/H last summer by a reputable local machine shop. The shop assembled the engine and set the valves. Had them install hydraulic lifters thinking them to be an upgrade and would quite the engine down. The engine runs great and is a heck of a lot quieter.
I have 1200 miles on the O/H now and I noticed the last two times I've started it, when the engine was cold, it has a slight tick coming from the valve train. Once the engines is warm, the tick goes away.
I reviewed your note on Jeff's hydraulic valve adjustment procedure where you state that machine work has to be completed when changing from solid lifters to the hydraulic lifters for them to work correctly. What does this machine work consist of? I'd like to have some insight on what exactly needed to be done before I call the machine shop. My guess is the shop did the required machine work and that the valve train just needs a little adjustment after break in.
Have you had to adjust hydraulic valves on any of your engines after break in?
Thanks
Thanks
