The 261 engine is a very good choice for a little added horsepower in our vintage trucks. The 261 was only available on large trucks from 1955 through 1962. They all came with solid lifters and most of them had a special thermostat on them. Since the cylinders are siamesed and they get hotter quicker, and since they are made for large trucks carrying very heavy loads, the standard 2-1/8" thermostat was not enough. In addition some extra engineering took place since they wanted the thermostat to be bypassed to a small extent on startup before the engine reached its temperature. Lots of guys do this on their 216/235 engines by drilling an 1/8" hole or two in the thermostat. The actual 261 thermostat was designed specially for this purpose and both upper and lower thermostat housings were made differently to accommodate the bypass thermostat that was available at the time. So far, I have searched and came up short on a new bypass thermostat. There is one that is a three piece model, but not very well designed.
For those of you who have never seen the difference between a 235 thermostat and housings and the 261 models, here are a few pictures. The two that I have were out of CLS60 models which is 1961's version of the 6000 series. Remember they only came equipped in heavy duty trucks. There is a rumor that there is a larger diameter version that can accommodate radiator hoses larger than the standard 235 ones, but I have never seen one. When asked about this, I am given the same exact casting numbers that are on the ones pictured, so if anyone has pictures of such a beast, I am always happy to include new information.
