Welcome to the 50th straight Tip of the Week. This week out of necessity, I am documenting how to change out the Windshield Glass on a 1953 Chevy 3100. These steps would be the same for all Advance Design Era trucks from 1947-1953. To do this job right, we have to remove the old windshield and rubber and take a close look at the condition of the metal around the windshield opening. It is not within the scope of this article to go into how to do the sheet metal repairs, but it is very important to especially check the lower outside corners and the lower middle junction for rust-through damage. These areas are especially prone to damage because GM never used weatherstrip adhesive, or any kind of sealer when installing these windshields in the first place. They were just installed dry. This can be problematic because if there is any path for water to accumulate, you can bet that it will. When it does, it does a lot of damage.
Most of the hard work is done on a flat table where you first attach the glass to the rubber. They use only one special tool that basically slides under the rubber in between the rubber and the glass to massage the rubber in place. The glass is completely installed in the rubber, both sides, and only then is it ready for installation. But wait! There is one more VERY important step. Take a long piece of nylon rope and put it inside the lip that fastens the rubber to the trucks opening. Go all the way around with the rope and begin and end at the center post area and at the bottom. This is an essential step. This is still working on the flat table.
