My fab skills are limited, but an idea for the Farm it out section. I'm using a t5 behind my 261 and a 55.1 rear axle. Problem is the t5 shifter from the s-10 doesn't line up with he factory 4 speed flor pan. What if you took the hump from the 4 speed floor pan and fabricated it to the flat 3 speed floor pan to line up with the T5 shifter from a S-10? Btw, I'm restoring a 51 chevy 5 window I've had since I was 14....22 years ago!
Not sure if this is the right area, but I'm sure others have run into this same issue and have limited resources for a solution.
