I see the '47-'53 lube chart shows the distributor getting oil/grease. Does my '58 235 distributor have any lube requirements? Thanks, Terry
Distributor lube
Hi Terry! I use regular, everyday, gear grease. The same as when you lube the chassis. Unscrew the grease cup, clean it out really good and fill it up. Then screw it in a few turns. Every now and then, give it another few turns pushing the grease through the spring, onto the pad and into the shaft. Brilliant in its simplicity!Deve Krehbiel
- Likes 1
Yeah, some of the rebuilders cheaped out and put a zerk in that hole. It is not the same really. It doesnt provide any push except when you grease it so the grease doesnt last very long on the shaft. I make a habit of giving that cup a 1/4 turn every thousand miles or less. Not sure if that is enough or not, but its better than nothing!
- Likes 1
