Hi Deve, it's been a while since I last posted as I've been enjoying cruising in my truck (49 Chevy with a 1954 - 235 and 3 speed). Recently, it had been hard to start, so I started looking at the timing by using the static timing method on your site (works like a charm btw) found out the culprit was likely the rust on the tip of the rotor... While i was hand turning the engine to get it to be at TDC, I noticed that it was harder to turn even with all the plugs out. On top of that, it was making a distinct hard creaking sound from somewhere inside the engine, almost like a bolt that is being over-tightened, or a dry leaf spring pivot which made me think metal on metal, slipped bearings, or something worse. Any thoughts on what it could be?
Despite my better judgement, I wanted to see if I could start the it, and managed to to get it running. I let it idle while I got the timing right, and blipped the gas a few times. Sounded ok, seemed to idle fine so I shut it off, but felt like I would be mothballing it for a while until I figured out what was causing the squeak. I haven't tried to turn it by hand since I last ran it, so I don't know if lube found its way in there to stop the squeaking.
I've always wanted to learn how to do a rebuild, but machine shop cost/time is something that I am not looking forward to in terms of setting up the block and head, not to mention buying any new engine parts. Budget is my biggest concern and I've already convinced myself that the snowball effect of trying to change power plant type isn't really in my grasp either.
Any thoughts or insight would be appreciated!
mark
mark
