Hello Everyone, first time posting here but long time lurker. I have been struggling to get a tight seal between the water pump adapter that relocates the water pump up a little higher to the radiator. I have a 261cui Chevy Engine with a 1954 Chevy truck water pump. The water pump to adapter plate is no issue. It is sealed very well with no coolant leaking. The issue I have been having is between the plate and the engine block, leaking on the bottom edge of the plate. I have removed and replaced the plate with various gasket configurations about five times and still the same issue. I have first tightened the bolts that hold the plate directly onto the block and then torque the top ones per the instructions. Perhaps I shouldn't even use a blue gasket at all and simply use RTV only between the plate and the block? Please advise! Thanks.
Juan
Juan
