In a previous post I reported a problem with contact between the oil pump pick up tube and #5 connecting rod in my 57 chevy 235. Turned out the tube was bent. I dropped the bottom plate to remove the bent pipe and the gasket was damaged in the process. Now, it appears, GM #838451 has been discontinued and none of the local dealers or parts stores still stock it. My online search so far is also coming up empty. From reviewing old threads on this subject, this has been a problem for a number of years now. Has anyone out there found a source for this elusive part, outside of what comes with a new pump or rebuild kit?
Some of the old posts suggest making a DIY gasket from a piece of paper, being careful to find paper as close as possible to .009" thick. Is this a safe option?
