The shackle bushings on my 1953 half ton rust bucket are shot and must be replaced. So far, I haven't budged the ones in the frame hangers. I've tried heat. Today I tried pulling them out using a 1/2 inch forged I bolt through the center. I twisted the threads off of the bolt which is rated at 2000 lbs., and didn't budge the bushing. I'm curious as to what methods you guys use to remove these bushings. I replaced all of them on my 1940 half ton, and it was quite a job, but so far this 1953 seems worse. I have made no progress.
Shackle bushings for leaf springs
Mike, I would use a 1/2" Hardened bolt so it doesn't strip as easily with a breakover bar and hardened socket WHILE applying heat using an acetylene torch to get it good and hot. With a helper keeping the heat on, turn the bolt. It will come out. If it doesn't it will be time to drill it out with just the right bit so as not to ruin the threads. I do not know the proper size. I think heat/bolt will do the job.
Or you could always do it the Dave Folsom way.. which is probably better: http://chev235guy.blogspot.com/searc...ring%20ShackleLast edited by Deve; 08-17-2018, 10:22 AM.Deve Krehbiel
- Likes 1
