I have a 235 installed in my 58 Apache. I have replaced the gas tank, fuel pump, fuel lines and fuel filter/bowl assembly with new units as part of the rebuild process. The engine starts and runs fine. My problem is this; after I park the truck for a few hours the glass bowl on the fuel filter that's connected to the carb, loses fuel down to about half of the bowl capacity. This creates a minor
problem starting as I have to crank it until the bowl fills again. There are no external leaks on the carb, fuel filter assembly or lines.
My technical advisor (older brother, he can't be right) tells me the float in the carb is sticking open or is miss adjusted. My theory is that the heat from the manifold cause the fuel to evaporate when the truck is first shut down. Again the truck starts fine as long as the bowl is full of fuel and there are no fuel leaks anywhere.
Any other possible causes? Do I actually have a problem or is this normal?
