I'm building a 1954, 261 and have modified it for the full flow oil filtering, I have and like the original oil filter canister that was in use as a by-pass oil filtering system. As I was a fixin to reinstall it on the manifold as before, it dawned on me that the amount of oil (volume) the By-Pass filter canister will pass is probably a lot less than required to keep up with engine requirements. Is that a correct assumption? Can I modify the original canister for increased volume ?
Thanks to all,
Bill
Thanks to all,
Bill
