First off, thanks Deve for this amazing resource! Such a great website, making it a pleasure to work on our truck.
I'm rebuilding a Rochester B for a 59 261, unfortunately it is a 235 carb but it is in very nice condition, I believe I could reuse all the parts but I have a nice rebuild kit from a local store. I noticed that the accelerator pump plunger currently in it has a rubber seal, whereas the kit uses leather. Also the float needle in it is solid metal, but the replacement has a rubber tip. It's probably a nit-picky question but is there any reason to prefer one or another? I would think because of problems with ethanol fuel I should use the metal needle but not sure if leather or rubber will hold up longer in the accelerator pump.
any advice or suggestions appreciated thanks!
