hi ya'll i'm working on a 1951 chevy , 216, 3 spd. i have posted this issue before and while i received some great leads and suggestions, such as a short or bad ground, after addressing those issues, the problem remains.
this is the issue. i don't know the history of the car but i do know that it was not on the road since the mid 70s. i brought the car home and got it running and i still have some work, but it seems to be a runner.
the problem is starting. some times i push the button and everything works as it should. sometimes i push the button and i get a loud clicking sound and thats it. if i continue pushing the start button, i'll notice some white wisps of smoke coming from the starter button at which time i'll give it a rest and it may or may not start later.
what i have done so far is replace the coil, battery, (still 6 volts) replaced the starter solenoid, new ignition key/switch, new starter button, rewired the ignition circuit, points, plugs, cap, condenser, rotor, and wires, but still clicking....sometimes.
so this morning, i was reading deve krehbiel's book on these engines and he mentioned that there are 2 different flywheels and i got to thinking that maybe the flywheel and starter gear don't mesh quite right all the time. to test this, i tried to start the car. when the clicking sound happened, i went under the car and moved the flywheel slightly by hand and the starter engaged and presto! i tried it a few times and it seemed to work. so my question is, could the flywhell be the cause and if so, what are my options?
also worth noting is that most of the old wiring for the lights etc remains. it is the original cloth and to say it is in bad shape, well lets just say it is. with the exception of every wire that is in the ignition circuit, the old stuff remains.
as always any and all suggestion would be a great help!
thanks
thanks
