Here is a brief explanation of each week's Tip. Tips are chosen by listening to our Forum traffic and Emails. If you would like to see a subject covered, let us know and we will be happy to consider your request.
YEAR 2016 (October to October)
Tip of the Week ONE: Restoration Tips, Links, How to Identify Your Engine
Tip of the Week TWO: Restoration Expectations, Preservation Ideals, Resources
Tip of the Week THREE: Essential Tools and necessary Shop Space
Tip of the Week FOUR: Heater System Maintenance and Resources
Tip of the Week FIVE: Important Flywheel/Starter Information
Tip of the Week SIX: Introduction to Electrical DC Principles
Tip of the Week SEVEN: Using the Multimeter for Troubleshooting
Tip of the Week EIGHT: Advanced Multimeter Operations
Tip of the Week NINE: Electrical Wiring Terminals
Tip of the Week TEN: Prepping and Painting Small Parts
Tip of the Week ELEVEN: Newer Style 235 Fitment/Electric Fan Issues
Tip of the Week TWELVE: Finish Items and Metal Shaping Small Parts
Tip of the Week THIRTEEN: Sending Unit Operation
Tip of the Week FOURTEEN: 6 Volt Fuel Gauge Solutions for 12 Volt Operation
Tip of the Week FIFTEEN: Converting to 12 Volts vs. Native 12 Volts
Tip of the Week SIXTEEN: Using Old Cell Phone Power Supplies to Power Battery Powered Items
Tip of the Week SEVENTEEN: Learning Software Programs to Enhance Your Restoration Capabilities
Tip of the Week EIGHTEEN: Equipping Your StoveBolt with an Oxygen Sensor
Tip of the Week NINETEEN: HEI Questions Asked and Answered by the Pros
Tip of the Week TWENTY: Some Vendor Information that May Help
Tip of the Week TWENTY ONE: Alternator Brackets when Using the Water Pump Adapter
Tip of the Week TWENTY TWO: Alternate Water Temperature Gauge Sensor Locations
Tip of the Week TWENTY THREE: Installing Your Distributor (if you do not know the timing orientation)
Tip of the Week TWENTY FOUR: Servicing your Door Hinges
Tip of the Week TWENTY FIVE: Exploring the 261 Thermostat Setup
Tip of the Week TWENTY SIX: Valve Cover Tips
Tip of the Week TWENTY SEVEN: 47/48 AD Cab Anomalies
Tip of the Week TWENTY EIGHT: Vacs and Sandblasting Cabinets
Tip of the Week TWENTY NINE: AD vs TF Front Hub Differences [more]
Tip of the Week THIRTY: Water Pump Adapter Plates and Alternator Brackets Pt 2
Tip of the Week THIRTY ONE: Thermostats and Jiggle Valves
Tip of the Week THIRTY TWO: Invaluable Rochester B Carburetor Information
Tip of the Week THIRTY THREE: Part One of a 1953 Wiring Harness Install
Tip of the Week THIRTY FOUR: Part Two of a 1953 Wiring Harness Install
Tip of the Week THIRTY FIVE: Part Three of a 1953 Wiring Harness Install
Tip of the Week THIRTY SIX: Part Four of a 1953 Wiring Harness Install
Tip of the Week THIRTY SEVEN: Running Board Installation Issues
Tip of the Week THIRTY EIGHT: Part One of Cab Sheet Metal Repair
Tip of the Week THIRTY NINE: Part Two of Cab Sheet Metal Repair
Tip of the Week FORTY: Part Three of Cab Sheet Metal Repair
Tip of the Week FORTY ONE: Door Hinge Repair Revisited in Detail
Tip of the Week FORTY TWO: Electrical Accessory Management
Tip of the Week FORTY THREE: AD Clutch System Maintenance
Tip of the Week FORTY FOUR: AD Bed Maintenance/Restoration Pt 1
Tip of the Week FORTY FIVE: AD Bed Maintenance/Restoration Pt 2
Tip of the Week FORTY SIX: 3.55:1 Gear Ratio Swap Advantages
Tip of the Week FORTY SEVEN: New Differential Overhaul How-To/Deep Thoughts
Tip of the Week FORTY EIGHT: Rare Transmission Adapter
Tip of the Week FORTY NINE: Engine Tech: Shimming Insert Bearings
Tip of the Week FIFTY: AD Windshield Installation
Tip of the Week FIFTY ONE: Self Canceling Blinker Systems Part One
Tip of the Week FIFTY TWO: Self Canceling Blinker Systems Part Two
YEAR 2017 (October to October)
Tip of the Week 53: Electric Fuel Pumps for Vintage Vehicles
Tip of the Week 54: Electric Fuel Pumps for Vintage Vehicles Part Two
Tip of the Week 55: Electric Fuel Pumps for Vintage Vehicles Part Three
Tip of the Week 56: As the Brake Drum Turns
Tip of the Week 57: 1954-1962 235/261 Torque Specifications
Tip of the Week 58: Speedometer Gear Solutions
Tip of the Week 59: Dave's Blog Site; As Good As It Gets!
Tip of the Week 60: Upper Engine Oiling Issues
Tip of the Week 61: Inserting Rivnuts/Nutserts
Tip of the Week 62: Carb Hats Made.. Easy?
Tip of the Week 63: AD Harmonic Balancer/Pulley Excitement
Tip of the Week 64: Amazing Blog Sites Worth Mention
Tip of the Week 65: Gyro's and Accelerometers Oh My!
